Hello. I'm planning on building a new PC just for gaming i'm not going to do any sort of photoshop or video editing its going to be just for gaming. I want to play games like Overwatch Battlefield V and borderlands 3 and other games and i want to run them at 1440p@144hz with high to ultra high settings ( if the game can't run at ultra high setting on 1440p 144fps i will set it to high ). This is the setup that i was thinking about tell me if it's any good and if there is any sort of changes that i should do. Thanks
CPU: i5-9600k 121 OMR ($315USD)
GPU: MSI GeForece RTX 2080 SUPER GAMING X TRIO 347 OMR ($901USD)
RAM:G.skill 16GB TridenZ DDR4 3200Mhz 49 OMR ($128USD)
CUP CoolerBe Quiet! Dark Rock Pro 4 38 OMR ($100USD)
MotherBoard: MSI MPG Z390 Gaming PRO Carbon LGA1151 89 OMR ($231USD)
SSD: Crucial P1 1TB 3D NAND NVMe PCIe M.2 SSD 48 OMR ($125USD), I have 1TB + 2TB HDD 7200rpm from seagate they will be used to store most of my games and a 120GB SSD from ADATA
In total the PC is going to cost me 692 OMR ($1800USD) and i still don't know which Case i will buy and i have a PSU its Corsair RM750 Fully Modular PSU.
I know that this system is expensive and you might find it cheaper in some stores like amazon and newegg but unfortunately i can order from them because i live in Oman and i heard that newegg doesn't ship to Oman ? .
https://linustechtips.com/topic/1124568-building-a-pc/
How much does a Ryzen 5 3600 cost you with something like an x570 prime p? It will have much better performance in battlefield V and do just as well in the other games you listed.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1124568-building-a-pc/#findComment-13053043
The Ryzen 5 3600 cost 93 OMR ($241USD) and x570 prime p cost 86 OMR ($227USD)
https://linustechtips.com/topic/1124568-building-a-pc/#findComment-13055659
Seems like a significantly better deal then
Primary PC:
PSU tier list
https://linustechtips.com/topic/1124568-building-a-pc/#findComment-13055734
