So I've made this website for a family friends business (www.andrewpaulfurniture.co.uk) on Squarespace. I need help in lowering the opacity of the big black box on the homepage of the website. I have seen other example sites on Squarespace that use the same template and have a lower opacity box. I have 0 knowledge of CSS.
I have put the question on the Squarespace help site but sadly didn't get a response.
Thanks
Intel Core i5 2500k @ 4.2GHz | Corsair Vengeance 16GB 1600MHz | MSI GTX660 Twin Frozr II OC | Samsung Evo 850 250GB | Seagate Barracuda 3TB | Corsair 600T White | Corsair H100 | Corsair HX850 | Corsair SP120 QE | Asus MX279H | LG Flatron E2251 | Logitech G502 | Das Keyboard Ultimate 4 Browns | Fiio E10 | Beyerdynamic Custom One Pro | Corsair SP2500 | HTC One M8 | MacBook Air (Mid 2013) i5 8GB 128GB
https://linustechtips.com/topic/112400-squarespace-css-help/
With CSS3 you can use something like this :
big_black_box{opacity:0.5;filter:alpha(opacity=50); }
The second line is for compatibiltiy with IE's older versions. I'm not sure wether or not this is only for images, I never used it.
You can also use this when assigning the background color to the box :
background-color:rgba(255,0,0,0.5);
The first three numbers are RGB values, and the third is the opacity.
https://linustechtips.com/topic/112400-squarespace-css-help/#findComment-1502840
