Logitech G533 Drivers cause problems
I recently bought a Logitech G29 with comes with the Logitech G Hub drivers to work properly, this also install the drivers for my G533, you might think that this is okay, but everytime I install the drivers for my headset, it always ends up in me deleting the drivers because of the sound cutting out and in, this is the case again. If I delete the drivers from Logitech, everything is fine, having a game open or a browser doesn't really effect it but when I connect to a VC in Discord the sound cutting out and in is noticable to the point where it ends up annoying me... With the G Hub software open, the sound cutting in and out is almost always present, closing this will minimize this until I connect to a channel in Discord...
Does anyone know a solution for this?
https://linustechtips.com/topic/1122702-logitech-g533-drivers-cause-problems/
