My Cpu core speed fluctuates like every 3-5 seconds from like 3711.72 MHz all the way to 2543.40 MHz and sometimes all the way to 1753.23 then goes back up in like 2-3 seconds and ever since i upgraded from a gigabyte GA-A320M-S2H motherboard to a gigabyte B450M DS3H motherboard my peformance hasn't been the same, the fps seems to be worse, my cpu is a ryzen 5 2600 i have 2x4gb ram 2666mhz and in the bios i activated the xmp profile but in cpuz it shows 1064.1 dram  frequency how do i bring the ram speed to its said speed
https://linustechtips.com/topic/1120119-cpu-core-speed-fluctuates/
DDR doubles the speed so the the real speed is 2133MHz which is the minimum DDR4 speed,the XMP profile doesn't work?
When a CPU core is idling the clock speed goes down to save power.
You can disable AMD Cool & Quiet to force the CPU to stay at the maximum speed and voltage all the time.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
How do i disable amd cool and quiet on my motherboards bios i switched back to my first motherboard which is gigabyte GA-A320M-S2H
