Help me pick a cpu
8 members have voted
  1. 1. Help me pick a cpu
    • R5 1600 $99
      1
    • R5 2600 $120
      3
    • R7 2700 $170
      2
    • R5 3600 $194
      2
I just spent an hour looking at benchmarks and I'm even more confused, hopefully you guys can help.
Feel free and try and convince me to consider an Intel PC but I was hoping to upgrade my CPU in the future.
And I think I would have to spend like $30 more on the motherboard if I got 2700 X, plus I haven't seen very many benchmarks that take advantage of the extra 2 cores to match it but it's always close.
https://linustechtips.com/topic/1118741-help-me-pick-a-cpu/
you are picking from 100~200 range, meaning your gpu wont be anything crazy, gaming performance will be very similar on all of your choices.
2600/2700 will be good enough for most use case for a long time
https://linustechtips.com/topic/1118741-help-me-pick-a-cpu/#findComment-13007128
You think the 3600 will go down at least a little bit, I'm probably not going to get anything at least until November / December, if I get anything first if we the board or the ram.
Or should I just deal hunt
Or bite the bullet and spend 50-60, and by everything at the same time?
https://linustechtips.com/topic/1118741-help-me-pick-a-cpu/#findComment-13007160
