Hey there! Today I've built a new rig with Ryzen 5 2600 and Gigabyte RX 580 Gaming 8G. I've a monitor from Samsung SyncMaster S19B150. The thing is I have one DVI-D port and one VGA port in my Monitor, Whereas my CPU and GPU has 1 HDMI + 1 DVI-D port for each. (I mean CPU has 1hdmi+1dvi-d and GPU too has 1hdmi+1dvi-d). So the question is how should I connect my Display with them? Should I also have to Connect my GPU with monitor? Or is it enough to connect with CPU only? Please reply!! I'm stuck there ?
https://linustechtips.com/topic/1115124-cable-management-with-display/
You should connect using the best possible cable from your GPU to your monitor. Based on your monitor, this would be the DVI-D connection on the monitor, so run a DVI cable from that to the DVI-D port on your GPU and you'll be set.
Desktop: KiRaShi-Intel-2022 (i5-12600K, 5060 Ti) Mobile: Moto Razr 50 Ultra (Razr+ 2024) | 30GB CAN+US+MEX $30/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
So I don't need to connect it from CPU? Only Connect my Monitor to GPU via DVI-D is fine?!
Yup... you only need one input and output between your display and graphics output, so going from GPU to monitor is what you need.
