Posted October 17, 2019 Hi I have built a pc a couple off weeks ago the spec is as follows ASRock X570 Phantom Gaming 4 AM4 DDR4 ATX Motherboard AMD Ryzen 7 3700X AM4 CPU Corsair Vengeance RGB Black PRO 16GB (2x8mb) x2 MSI GeForce RTX 2080 GAMING TRIO 8GB Graphics Card Samsung 970 EVO Plus V-NAND M.2 250GB SSD Seagate FireCuda Desktop 2TB Hybrid Hard Drive (SSHD) 3.5" SATA III 6GB's 7200RPM 64MB Cache EVGA 100-BR-0700-K3 700 BR, 80+ Bronze 700W, Power Supply Now the problem im having is the memory is running at 2133mhz when the oc is on auto however when i select xmp profile it sets the memory to the 3200 as it should be my score in 3dmark go's up however ive noticed the pc is a little unstable is their anything i'm missing out on as even tho i can run all my games @ 4k with over 60fps I would really like my memory to be running at the rated speed. Thanks in advance. Link to comment https://linustechtips.com/topic/1114578-memory-not-running-fast-enough/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 17, 2019 38 minutes ago, reaperdrb said: Hi I have built a pc a couple off weeks ago the spec is as follows Just up the voltage for the DDR4 to 1.4V I edit my posts a lot, Twitter is @LordStreetguru just don't ask PC questions there mostly... Spoiler What is your budget/country for your new PC? what monitor resolution/refresh rate? What games or other software do you need to run? Link to comment https://linustechtips.com/topic/1114578-memory-not-running-fast-enough/#findComment-12974094 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 17, 2019 Tell it to work out more Link to comment https://linustechtips.com/topic/1114578-memory-not-running-fast-enough/#findComment-12974218 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
