I have an older Seagate "white label" Barracuda hard drive and recently I've been having super long booting times and some BSOD's and post errors on startup. A day or two ago task manager was showing response times in the 1000ms+ range on the drive and it wouldn't even show up in task manager about an hour ago (It does now after a little bit of tinkering). Now this drive has gone through many many hardware changes, it has had about 2 different graphics cards and an entire motherboard/CPU/Ram swap without a reinstall of Windows(Yes I know). Now this drive is about 6 years old if I recall correctly and I am not sure as to the prior use of this drive, it was given to me used. I went ahead an ordered a 128GB SSD from PNY knowing I would have to reinstall Windows because of the hardware changes. My question is, do you think the drive would be safe to use as a secondary mass storage drive, after all its about half full as is and a 128gb SSD is no where near half the capacity of the 1TB drive. I would wipe the drive completely and install Windows on the SSD and get any necessary applications installed first then I'll see if I actually need the drive or not. Thanks!
https://linustechtips.com/topic/1112612-dying-hard-drive/
