So my friend just texted me that he couldn't open discord, so he tried to uninstall and reinstall, but it wouldn't let him install it. Has anybody else had this issue.
Sorry for lack of info as i am not experiencing it myself and he is not very familiar with computers.
CPU: Amd Ryzen 3400g
COOLER: Be Quite Dark Rock Pro 4
MOBO: Aorus x570 elite
RAM: 2x8 Corsair Vengence 3200 MHz
SSD: Samsung 970 Evo Plus 500GB
GPU: Powercolour Red Devil RX570 4GB
PSU: Corsair RM750x 80+ Gold
CASE: Coolermaster H500p Mesh
https://linustechtips.com/topic/1106422-discord-issues/
Here are some steps for your friend to try if he is having issues installing Discord:
1) Temporarily disable your antivirus programs and firewalls
2) Terminate all Discord processes in Task Manager
3) Completely remove and clear Discord from your system by deleting the Discord folders from both %AppData% and %LocalAppData%
4) Restart your PC
5) Disable antivirus programs and firewalls one more time
6) Run the Discord installer (DiscordSetup.exe) as Admin
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
https://linustechtips.com/topic/1106422-discord-issues/#findComment-12909116
4) Restart your PC
tbh he prob just didn't run the installer
https://linustechtips.com/topic/1106422-discord-issues/#findComment-12909507
