Swaped cooler
Solved by WoodenMarker,
4 minutes ago, Tottenstein said:thats the thing my temps are fine and i know the pump is running its just that sometimes even tho my system isnt maxed my computer just frezes for a cuple of secounds and then is fine again and it feels like i have worse performance then i should in some games
Have you tried reseating the cooler? If it's unevenly mounted, it can cause those types of issues. Make sure to gradually and evenly the block in an X-pattern instead of one side before another.
