Only vertical mounting that makes sense would be the Cable-mod bracket. Any case Vertical mount is worthless and provides poor performance due to choking the fans from air.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
That wouldn't work with my new GPU. Im buying the 2070s Aorus and it says in cable mod's website that it doesnt support graphics cards with 3-slot PCI-e and the Aorus is actually a triple slot card.
so then its not worth it as you will choke the card so hard causing thermal throttle of the card because it will have no room to intake fresh air as a result.
Community Standards
"Beast Mode"
