One day I was playing roblox (yes, roblox.) and straight out of left field, my graphics card fans start running at 100%! It scared the crap out of me. My first instinct was to open msi afterburner and shut the fans off automatically, hopefully it would tell me what's wrong, but the program didn't even tell me that the fans were running. When I looked at the physical graphics card, only one of the fans was running at full speed. The other wasn't running at all. And I figure software isn't designed to run only one of the fans. They always run together. I restarted my computer, and found that it happens every time the graphics card is running something a little graphically challenged (the sims, fallout, pretty much any game with textures). Everytime the fan is prompted to run, it runs at full speed and doesn't stop.
I have an msi GeForce GTX 1050 TI, I got it in early april and have been using it ever since.
I've attached two monitors in tandem with the computer's original integrated graphics.
Hopefully there aren't any other problems happening along side the fans malfunctioning. If anyone has any suggestions, I'll be glad to apply them, and hopefully find out what's the problem.
Thanks!
https://linustechtips.com/topic/1096515-gpu-fan-speeds-maximum/
