Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1095548-new-build-need-help/#findComment-12819693
1 minute ago, fasauceome said:
I am very, very familiar with Intel and would be more comfortable spending a little more money for it.
https://linustechtips.com/topic/1095548-new-build-need-help/#findComment-12819700
I'll recommend something like this instead..
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($329.00 @ B&H)
Motherboard: MSI B450-A PRO ATX AM4 Motherboard  ($79.99 @ Newegg) Supports BIOS flashback
Memory: Team T-Force Vulcan 16 GB (2 x 8 GB) DDR4-3200 Memory  ($65.99 @ Newegg)
Storage: Sabrent Rocket 512 GB M.2-2280 NVME Solid State Drive  ($59.98 @ Amazon)
Storage: Hitachi Ultrastar 7K3000 3 TB 3.5" 7200RPM Internal Hard Drive  ($52.23 @ Amazon)
Video Card: Sapphire Radeon RX 5700 XT 8 GB PULSE Video Card  ($419.99 @ Amazon)
Case: Fractal Design Meshify C ATX Mid Tower Case  ($83.99 @ Amazon)
Power Supply: BitFenix Formula Gold 650 W 80+ Gold Certified ATX Power Supply  ($75.99 @ SuperBiiz)
Total: $1167.16
Generated by PCPartPicker 2019-08-18 23:31 EDT-0400
Most of the people here would recommend you AMD. Because right now AMD offers best performance per dollar.
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1095548-new-build-need-help/#findComment-12819712
more familiar with what aspect of it? If I put a PC in front of you, how would you be able to tell if there was an AMD CPU inside without opening task manager?
Primary PC:
PSU tier list
https://linustechtips.com/topic/1095548-new-build-need-help/#findComment-12819714
6 minutes ago, fasauceome said:
3200mhz cl16 for that price?? w
7 minutes ago, fasauceome said:
I think you,re well versed enough into SSDs to know why this isn,t a good choice...
well i do see it on OP,s list , but i think you would have known enough about SSDs to change it...
rx 5700 xt.
8 minutes ago, fasauceome said:
bitfenix formula gold 550.
https://linustechtips.com/topic/1095548-new-build-need-help/#findComment-12819715
rx 5700 xt.
literally just copied OP's list with Ryzen and better PSU, didnt bother changing anything else
Primary PC:
PSU tier list
https://linustechtips.com/topic/1095548-new-build-need-help/#findComment-12819723
It's like Android and Apple, I just prefer one over the other.
https://linustechtips.com/topic/1095548-new-build-need-help/#findComment-12819724
literally not a thing like android and apple. using an apple phone is entirely different than an android phone.
again, how do you know the difference from using it?
Primary PC:
PSU tier list
https://linustechtips.com/topic/1095548-new-build-need-help/#findComment-12819726
Windows on Intel CPU runs the same as windows on AMD. So does Linux.
AMD is on par with Intel in gaming. Also it has higher multicore performance as compared to similarly priced Intel CPUs.
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/1095548-new-build-need-help/#findComment-12819733
He asked for your help. He obviously likes one over the other. Also with your explanation, why wouldn't everyone one buy amd? It's a preference, like I said, to some.
https://linustechtips.com/topic/1095548-new-build-need-help/#findComment-12819744
2 minutes ago, VEXICUS said:
So does Linux.
unless you're using a 2990WX and the task scheduler doesn't shit the bed, then AMD is way better lol
Primary PC:
PSU tier list
https://linustechtips.com/topic/1095548-new-build-need-help/#findComment-12819745
Alright, Im gonna get into the nitty gritty. I swapped from a 2700X to a 9900K and with the new ryzen CPU's They are pretty much head to head now. For the same price you get more cores with the same IPC and you have the ability to stream and not sacrifice performance from it. If I were you, Honestly I'd go for 3rd gen ryzen and not having to upgrade your mobo everytime a new cpu is out is nice. :)
CPU: Intel Core i9 9900K | Ram: 32GB Corsair LPX 3200 DDR4 | Asus Maximus XI Hero Z390 | GPU: EVGA RTX2080 XC | 960 EVO Samsung 500GB M.2 | 850 EVO Samsung 250GB M.2 | Samsung 1TB QVO SSD | 1TB HDD WD Blue
https://linustechtips.com/topic/1095548-new-build-need-help/#findComment-12819750
https://linustechtips.com/topic/1095548-new-build-need-help/#findComment-12819756
my help was to give helpful advice. There are extremely few objective reasons to choose Intel right now, and they all involve Adobe or AVX workloads. Brand loyalty gets you nowhere but an emptier wallet.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1095548-new-build-need-help/#findComment-12819759
Motherboard: MSI B450 TOMAHAWK ATX AM4 Motherboard  ($114.89 @ OutletPC)
Memory: OLOy WarHawk RGB 16 GB (2 x 8 GB) DDR4-3200 Memory  ($66.99 @ Newegg)
Storage: Seagate Constellation ES 3 TB 3.5" 7200RPM Internal Hard Drive  ($56.99 @ Amazon)
Video Card: XFX Radeon RX 5700 XT 8 GB Video Card  ($399.99 @ Best Buy) AIB card if you can wait for stock.
Case: Corsair SPEC-DELTA RGB ATX Mid Tower Case  ($89.98 @ Newegg)
Power Supply: EVGA SuperNOVA G2 550 W 80+ Gold Certified Fully Modular ATX Power Supply  ($84.85 @ Walmart)
Total: $1202.67
Generated by PCPartPicker 2019-08-18 23:50 EDT-0400
https://linustechtips.com/topic/1095548-new-build-need-help/#findComment-12819769
2 minutes ago, WebPlayz said:
3600. is a thing. and i can guarantee you the stock cooler upgrade is not worth $40 lol
3 minutes ago, WebPlayz said:
on a ryzen? Why? ryzen,s voltage curve is insanely steep ,  ur getting minimal gains from this..
4 minutes ago, WebPlayz said:
There is cheaper rgb ram
For gaming??? and even if OP for some reason wants mid-high end NVme for his build , then you should have recommended the sabrent rocket 512gb which is $20 cheaper for similar sustained workload performance
5 minutes ago, WebPlayz said:
rx 5700 xt.
First off , 550w is more than enough for the build. "Headroom" should not be consider as parts will onlyget more efficient in the future due to die shrink and the like. Bitfenix formula gold 550 is $70 onnewegg and similar quality to rmx
https://linustechtips.com/topic/1095548-new-build-need-help/#findComment-12819773
Sapphire pulse cards are available for just $20 more. It's worth $20 for a better cooler.
https://pcpartpicker.com/product/3YTzK8/sapphire-radeon-rx-5700-xt-8-gb-pulse-video-card-11293-01-20g
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/1095548-new-build-need-help/#findComment-12819776
i put down the reference 5700XT because the pulse wasn't in stock at both sites.
https://linustechtips.com/topic/1095548-new-build-need-help/#findComment-12819782
1 minute ago, hello_there_123 said:
formula gold 550 is $70 on newegg just letting u know
650w for $5 more should be a better buy.
Total: $1167.16
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/1095548-new-build-need-help/#findComment-12819788
It is a bit unnecessary but the efficiency peak of the PSUs is usually found when they work in the middle of their capacity. That is, if you need 650w but you get enough funds to buy a 1200w PSU then the performance of the PSU will be better than it reaches amounts of power close to its limits, again this something that not anyone would care but this is the reason why when you see the lights flickering a bit on almost anything, utility poles, etc... Because the power fluctuates but it is handled better when the power supply is not demanded to work at a %100, below some images for reference:
Resultado de imagen para psu efficiency curve
Seagate Technology | Official Forums Team
IronWolf Drives for NAS Applications - SkyHawk Drives for Surveillance Applications - BarraCuda Drives for PC & Gaming
https://linustechtips.com/topic/1095548-new-build-need-help/#findComment-12822010
