NEED HELP (part 2 ;( sorry)
Go to solution Solved by Herman Mcpootis,
PCPartPicker Part List
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor  ($133.00 @ Amazon)
Motherboard: ASRock B450M PRO4 Micro ATX AM4 Motherboard  ($79.88 @ Amazon)
Memory: Team Vulcan 16 GB (2 x 8 GB) DDR4-3000 Memory  ($67.89 @ OutletPC)
Storage: Patriot Burst 480 GB 2.5" Solid State Drive  ($47.99 @ Newegg)
Video Card: Gigabyte Radeon RX VEGA 56 8 GB Video Card  ($279.99 @ Amazon)
Case: Thermaltake Versa H15 MicroATX Mid Tower Case  ($29.99 @ Newegg)
Power Supply: Corsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply  ($64.99 @ Corsair)
Total: $703.73
Generated by PCPartPicker 2019-08-14 04:07 EDT-0400
So this is a update to my previous post, i turns out that only have a budget of $710. If you haven't seen my other post then i will give you a sample, so basically i need someone to help me build a gaming pc that will get the most out of my money, the game in specific is battlefield V but also includes Overwatch and a few AAA games. I need complete build because i currently use a mac :/.... Thanks for your help...Also i use a sb220q monitor and live in the US.
*edit*
I need something better or equal to this>>>>>
Edited by HUExGxRECTION
https://linustechtips.com/topic/1093752-need-help-part-2-sorry/
Do you need peripherals or no? Didn't see your last thread so if you answered that ¯\_(ツ)_/¯
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/1093752-need-help-part-2-sorry/#findComment-12805468
no i already have keyboard, mouse and monitor, but if you were able to add a headset like a corsiar hs60 that would be great :)
https://linustechtips.com/topic/1093752-need-help-part-2-sorry/#findComment-12805495
Alright so this is what I came up with. Covers all the basics for what current-day competent gaming PCs tend to have, with about ~30 bucks left over after MIR and promo discounts to put towards something like the HS70 (at least before shipping, I can't really account for that).
PCPartPicker Part List: https://pcpartpicker.com/list/yVW9xG
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor  ($132.79 @ Amazon)
Motherboard: MSI B450 TOMAHAWK ATX AM4 Motherboard  ($114.99 @ Best Buy)
Memory: Crucial Ballistix Sport LT 16 GB (2 x 8 GB) DDR4-3200 Memory  ($69.99 @ Newegg)
Storage: Crucial BX500 240 GB 2.5" Solid State Drive  ($31.99 @ Newegg)
Storage: Hitachi Deskstar 7K2000 2 TB 3.5" 7200RPM Internal Hard Drive  ($38.49 @ Amazon)
Video Card: Sapphire Radeon RX 580 8 GB PULSE Video Card  ($169.99 @ Newegg)
Case: Fractal Design Focus G ATX Mid Tower Case  ($49.99 @ Amazon)
Power Supply: EVGA BQ 500 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($54.99 @ Walmart)
Total: $663.22
Generated by PCPartPicker 2019-08-13 18:47 EDT-0400
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/1093752-need-help-part-2-sorry/#findComment-12805518
Total: $663.22
I just tried making my own so i was wondering if this would be any good compared to yours? >>>https://pcpartpicker.com/list/xskDr6
https://linustechtips.com/topic/1093752-need-help-part-2-sorry/#findComment-12805540
Personally I wouldn't go that route. Intel on a budget isn't the best of ideas, and the 1660 is not fast enough to warrant the (relatively) massive increase in price. You'd be gaining 5-10% in framerate while spending considerably more and losing damn near all of the space you'd have to store games.
Thinking about it a bit more though, something you may wish to consider if you want the HS70, you could swap out the 16GB RAM kit in my original list with this kit, as that should get you pretty much there (again, not taking shipping into account because I can't), and 16GB (while very nice to have) isn't absolutely necessary yet. But to play devil's advocate, you spend about 50% more for twice the RAM.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/1093752-need-help-part-2-sorry/#findComment-12805576
would there be a difference if i put a 570 instead of a 580?
https://linustechtips.com/topic/1093752-need-help-part-2-sorry/#findComment-12805656
You'd be taking a roughly 20% hit in most games with a good 570 8GB (4GB cards are pointless) for about 15% less money. Kind of a silly downgrade if you ask me.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/1093752-need-help-part-2-sorry/#findComment-12805670
if i were to upgrade, what would be upgraded, and with what? Thanks
https://linustechtips.com/topic/1093752-need-help-part-2-sorry/#findComment-12805712
Later on down the line if you're sticking to 1080p I think the only thing I'd want to upgrade would be the CPU to a 3000 series chip (at least if you went with 16GB out of the gate) as well as just slowly replacing peripherals until I had things I really liked.
If you wanted to make the jump to 1440p or 4K then I'd definitely place a priority on a better GPU (which at this point in time would be an RX5700/XT AIB card depending on pricing) and then a 3000 series chip.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/1093752-need-help-part-2-sorry/#findComment-12805764
Total: $703.73
https://linustechtips.com/topic/1093752-need-help-part-2-sorry/#findComment-12806378
CPU: Intel Core i5-9400F 2.9 GHz 6-Core Processor  ($142.89 @ OutletPC)
CPU Cooler: Deepcool GAMMAXX 400 Blue 74.34 CFM CPU Cooler  ($21.99 @ Amazon)
Motherboard: ASRock B365M Pro4 Micro ATX LGA1151 Motherboard  ($78.89 @ OutletPC)
Memory: Team Vulcan 16 GB (2 x 8 GB) DDR4-2666 Memory  ($59.99 @ Newegg)
Video Card: MSI GeForce GTX 1660 Ti 6 GB GAMING X Video Card  ($274.99 @ Newegg)
Case: Thermaltake View 21 Tempered Glass Edition ATX Mid Tower Case  ($44.99 @ Newegg)
Power Supply: Thermaltake Smart RGB 600 W 80+ Certified ATX Power Supply  ($44.99 @ Newegg)
Total: $716.72
Generated by PCPartPicker 2019-08-14 07:37 EDT-0400
https://linustechtips.com/topic/1093752-need-help-part-2-sorry/#findComment-12806781
no need cpu cooler bcause r5 3600 cooler is good enough . msi gaming plus has biosflashback , just update bios
https://linustechtips.com/topic/1093752-need-help-part-2-sorry/#findComment-12806828
