When I try to start Xenoverse 2 , I get this error. I have searched online and tried to troubleshoot the problem but it still appears. I have installed every single drive there is for my GPU.
I tried to re-install the game...
I tried to change the config_ini file
I tried to run as an administrator. Nothing so far.. Any suggestions?
https://linustechtips.com/topic/1091518-i-need-help-with-this-problem/
Try disabling the igpu if one exists
If you've installed "every driver", that might be the problem. The latest AMD/NVIDIA driver should be the only one you need. As @DotzHyper said, you can disable your iGPU, which might be causing the problem. This can be done by going to Device Manager (Windows Key + R > devmgmt.msc > Press Enter) > Display Adapters > Your iGPU > Driver > Disable Device.
What graphics card do you have?
A zotac geforce 750 ti 1 fan 2gb card
I think this is the driver you need:
https://www.nvidia.com/Download/driverResults.aspx/148865/en-us
Run DDU (Display Driver Uninstaller) first, then try the driver above.
Yea, man that doesn't work either.
Just now, FinishGamer86 said:
Yes, I did . I still get the same error. Probably because I have installed the same drivers (link you sent me)
I've helped other people through these sorts of driver problems before, albeit problems which were causing a BSoD.
If it's feasible, try a reinstall of Windows. If you've been using the rig for a while, then obviously that's not going to be ideal.
Just a sanity check, have you tried restarting in-between driver installs?
It's not a good idea to re-install windows because I can't save my files on a External HDD because I don't have one (and probably I won't have one for a while). And no, I haven't restarted between driver installs.
As dumb as it sounds, restarting could well be the issue. Having run DDU and reinstalled that driver, try restarting.
(it's a long shot but maybe)
