Help - mixed power cables
Go to solution Solved by SuperCloneRanger,
I doesn't really matter, both cables are rated far higher than either devices usage. But since the power supply uses more power i'd go 13A to power supply, 10A to the monitor.
I disconnected my computer because I needed to move it, but now I can't figure out which power cable goes to the Power Supply and which one goes to the Monitor.
Monitor: ViewSonic VA2719-2K-SMHD
Power Supply: Corsair RM850i
Both cables look nearly exactly the same, but the specs are different, mostly the wattage:
Cable 1:
E55943, LL41230
I-SHENG
IS - 14
13A, 125V, 1625W
Cable 2:
E55943, Ll41230
I-SHENG
IS - 14
10A, 125V, 1250W
Could someone please help me out? I don't want to fry my components or mess something up :(
Thank you
https://linustechtips.com/topic/1087765-help-mixed-power-cables/
