6 minutes ago, Origami Cactus said:
I would get index, Vive is a little outdated now, but it is dirt cheap on the other hand.
With all accessories it's still $500, and while that's $300 less than launch price, it certainly isn't dirt cheap, especially compared to the $400 rift S
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1087534-vive-or-index/#findComment-12757105
What accessories, you mean the wireless set or something?
Anyways rift S to me looks like it has even worse tracking than the original rift, but if you can prove me wrong im all ears. Does it track the controllers if you put them behind your back, or is it like the WMR headsets, that only track when they are in front of you?
Also AA batteries in the controllers? Is it 2008?
I only see your reply if you @ me.
https://linustechtips.com/topic/1087534-vive-or-index/#findComment-12757112
Like the lighthouses and stuff, you can buy headset only for like $200 but then of course can't use it for VR games
So far I haven't had any problems with the inside out tracking behind my head, I believe it uses a trajectory to estimate the path and if so it does a damn good job. Otherwise I think the Rift S honestly has a leg up on the Vive in comfort to wear and picture quality.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1087534-vive-or-index/#findComment-12757116
1 minute ago, CrazieChipmunk said:
@fasauceome i might think about getting the oculus rift s then, but there is one thing, i will only buy it if it works with the index controllers
Oculus headsets don't work with competing headset accessories unfortunately.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1087534-vive-or-index/#findComment-12757130
These all come with the base kit, no extra purchase required.
https://linustechtips.com/topic/1087534-vive-or-index/#findComment-12757139
