Hey everyone, I seem to have run into an issue with my network but only with my computer. My pc is plugged directly into my Xfinity Arris modem using a Cat 6 ethernet cable. I have my Xbox One and TV also plugged into the modem but I have not noticed any issues with them network wise. First my PC specs:
intel core i7 2700k OC 4.4
Corsair H100i Cooler
Asus Sabertooth z77
Corsair (4x4GB)16 GB RAM 1600mhz?
XFX Radeon 295x2
Mushkin Chronos 120 GB SSD
WD 3 TB green HD
EVGA G2 1000w PSU
A few weeks ago my network on my PC seemed to be bogged down even at start up. webpages wouldn't load, sign in verifications would time out. Browsing the steam store was impossible I get every different error page that exists. Usually if there is an issue with the network its due to comcasts shitty modem. I went to them and replaced it which didn't help. I am still not ruling it out though because it took me an hour to get it to cooperate with me and it was "new". Like I said before I have no issues with my xbox, PS4, or my smart tv, all are plugged in with ethernet cables while my ps4 is on wifi. I have a few devices on wifi but I have no issues with it at all.
Now I tried using all my different ethernet cables with my PC same issues. I decided to run a speedtest downloaded the speedtest.net app on the windows store. I found what seems to be the problem using this my download speed is 118mbps but my upload speed is an atrocious 0.02mbps. Running the speedtest on my xbox I get the same download speed but upload is between 4 and 5mbps still atrocious but that's normal for comcast. I found a wifi usb lying around and tried to use that and it does work slightly better with upload speed I get around 2 mbps but the download speed is only 50mbps and the modem is right next to it.
I tried reinstalling my network drivers, updating windows, I went to my moms house and tested it there same issues, windows troubleshooting says nothing, intels update tool says the ethernet port is working and theres no issues, device manager has no cautions, ran Malwarebytes for viruses and windows defender, used CCleaner to clean the registry and everything else. Seems I have done everything besides reinstall a clean windows or get a new motherboard which both of those I would like to avoid at the moment.
So I am seeking advice for this frustrating issue. Networking is not my thing and I hate diagnosing these problems. Thanks everyone
https://linustechtips.com/topic/1081834-random-network-issues-please-help/
