CPU TEMPS TOO HIGH
Go to solution Solved by Fakmykak,
Just now, Venomous468 said:
The ambient temp at my place is 35c
Well there is your problem. If you ambient temperature in your home is 35c. That would most definitely make your CPU run hotter than normal.
Hello, i have a i7 8700 (non-k) and i used to have a hyper TX3 EVO on it but it wasnt keeping it cool enough to hit the 4.3 GHZ mark so i bought a Thermaltake ring silent 12 pro for it which is a 170 tdp part cpu cooler but the temps are worse now before they would go to about 68c on gaming load or 70c on full load now after the new cooler installation its like 70c on gaming load and reaches almost to 80c under full load. ihave tried almost everything like > reapplying thermal paste, reinstalling the cooler, checked the airflow of the case even left the front panel open but it just doesnt seem to work. HELP!
https://linustechtips.com/topic/1081309-cpu-temps-too-high/
Clean paste, reapply and reseat and tighten screws a lot just enough before the motherboard chips.  If bad temps again then just stick with what you had.  70's c load is fine.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1081309-cpu-temps-too-high/#findComment-12711912
What is your ambient temperature. If it is warm where you live and inside your home it is like 80f. That could impact how hot your CPU runs.
But 70-80c is nothing to really worry about, it does seem a little high though.
Join HWBot or OCN
#1 3DM Fire Strike Ultra score in the world.
#2 3DM Time Spy Extreme score in the world.
#3 3DM Fire Strike Extreme score in the world.
#7 3DM Sky Diver score in the world.
#8 3DM Fire Strike score in the world.
#12 3DM Time Spy score in the world.
All scores obtained with 8600K + 1x 1070Ti. Links in bio
https://linustechtips.com/topic/1081309-cpu-temps-too-high/#findComment-12711941
https://linustechtips.com/topic/1081309-cpu-temps-too-high/#findComment-12711952
Join HWBot or OCN
https://linustechtips.com/topic/1081309-cpu-temps-too-high/#findComment-12711960
tell me about it.
I lived in the Philippines and the temps here at worse its 40~42C with some area hits 45C.
anyways, as long as your CPU dont hit that 85-90C temps, you're still fine. till you decided to replace your rig.
https://linustechtips.com/topic/1081309-cpu-temps-too-high/#findComment-12712031
Just now, Mega1987_VerOS said:
tell me about it.
Dang that sounds pretty bad. Hope your CPU is not overclocked haha
Join HWBot or OCN
https://linustechtips.com/topic/1081309-cpu-temps-too-high/#findComment-12712035
ha!
R5 1600, OC's to 3.9ghz @ 1.35v and My rig is chilling around 41-52C on idle while 76-82 C during stress test.
my room is not Aircon cooled. just fan assisted air circulation.
my CPU cooler is the Cryorig H5 Ultimate when i perma OC'd my PC to 3.9ghz.
and i was mostly gaming on it so it's not THAT bad on temps on actual usage.
https://linustechtips.com/topic/1081309-cpu-temps-too-high/#findComment-12712045
Nice. My 8600K is at 4.5 with 1.185v. It doesn't go over 50c in games, and with prime95 the hottest it ever got was 69c.
Gotta have them low temperatures!
Join HWBot or OCN
https://linustechtips.com/topic/1081309-cpu-temps-too-high/#findComment-12712068
