Help my games keep crashing
Solved by jones177,
Some GPUs will crash if there is an overclock in the CPU. This overclock can be the default setting on the motherboard.
Also MSI Afterburner false reports on the 2080 ti and I find I have to reboot the computer every time I change anything. I have EVGA cards so I run Precision X1 at the same time to check.
The best way to test is to put the card in another gaming computer. This is easy for me to do since there are 3 gaming computers in my home.
If you can't put it in another computer to test, RMA it.
