Hey guys.
I built my pc about 2 years ago.
Specs Intel Core i5 4460
Asrock B85m-itx motherboard
8gb ddr3 ram
It was working until i booted it up the other day now it turns on but doesnt display anything and will not turn off till i hard reset it. Does anyone know what the issue is?
https://linustechtips.com/topic/1078859-pc-not-displaying/
Unpluged and reconnected all the cables made sure everything was connected. I read that it could be the cpu but then i replaced it didnt work. Unpluged the gpu but still didnt work. Tested the PSU and it worked on another system. My next guess is thr motheboard
https://linustechtips.com/topic/1078859-pc-not-displaying/#findComment-12693552
Try a different port/cable (I notice that the B85m has HDMI and DVI-D so try the other cable into your monitor if you can)
You mentioned here (but not in the original post) that you have a GPU so ignoring the GPU try running a display from the motherboard directly
CPU
Intel® Core i9 9900K 8 Core 16 Threads
Motherboard
ASUS® ROG Strix Z390-E
Memory (RAM)
32GB Corsair Vengeance Pro RGB
Graphics Card
MSI RTX 2080 Gaming X Trio
1st Drive
500GB Samsung 970 EVO NVME
2nd Drive
1TB Samsung 970 EVO NVME
3rd Hard Disk
480GB KINGSTON HYPERX 3K SSD, SATA 6 Gb/s (upto 540MB/sR | 450MB/sW)
4th Hard Disk
2TB 3.5" SEAGATE SSHD, SATA 6Gb/s 7200 RPM
5th Hard Disk
Power Supply
CORSAIR 850W RM SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor Cooling
Corsair H150i Pr 360mm AIO
Case:
Lian Li O11 Air
https://linustechtips.com/topic/1078859-pc-not-displaying/#findComment-12693556
Haswell was many years ago, a lot more than 2 years. 2013-2014 era. If you built that PC two years ago, you must have used old parts and that doesn't make them 2 years old.
Old parts die. It's probably the motherboard. A perfect time to switch to Zen 2 Ryzen 3000.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1078859-pc-not-displaying/#findComment-12693585
