removing command running on start up
Go to solution Solved by Ben4wolves,
1 minute ago, SPARTAN VI said:
Start > "msconfig" > Then hop over to the "Startup" tab
Sort by "manufacturer" and you should find Thermaltake right there, or at least the .exe, then disable it.
this isn't it as that doesnt exist, neither does cmd. However i have actually fixed it. It's set as a scheduled task so you have to locate it in there and delete it.
Sort by "manufacturer" and you should find Thermaltake right there, or at least the .exe, then disable it. If it's not there, then try the "Services" tab, check "Hide all Microsoft Services" then disable it if it's here.
