Wait for ryzen 3000.
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
On 6/19/2019 at 1:36 PM, Craymarris said:
I plan to build within 2 to 3 months
I have never used Linux before, hows the learning curve and will Davinci work on it?
Doesn't DaVinci work on Windows 10? Why do you want to use Linux?
Why are you using a Quadro GPU?
What is your budget in local currency? Where do you live?
On 6/19/2019 at 2:21 PM, Craymarris said:
Consider a more powerful cpu. The 2700X would be good. As already suggested waiting to the second week of July to see the reviews of the new 3xxx cpu would be prudent.
The motherboard will not support the storage outlined. You will need an X470 motherboard.to provide sufficient open SATA III ports. When the new 3000 cpu are released there will be X570 motherboards that may be better choices.
I'd suggest getting a better quality psu. 550W - 650W is sufficient.
PCPartPicker Part List
CPU: AMD - Ryzen 7 2700X 3.7 GHz 8-Core Processor  ($279.89 @ OutletPC)
Motherboard: ASRock - Fatal1ty X470 Gaming K4 ATX AM4 Motherboard  ($149.99 @ Newegg Business)
Memory: Crucial - Ballistix Sport LT 32 GB (2 x 16 GB) DDR4-3000 Memory  ($139.99 @ Amazon)
Storage: Samsung - 970 Evo Plus 1 TB M.2-2280 Solid State Drive  ($227.17 @ Amazon)
Storage: Samsung - 860 Evo 2 TB 2.5" Solid State Drive  ($281.39 @ Amazon)
Video Card: PNY - Quadro P2000 5 GB Video Card  ($422.99 @ Amazon)
Case: Cooler Master - Stryker SE ATX Full Tower Case  ($149.99 @ B&H)
Power Supply: Corsair - RMx (2018) 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.99 @ Newegg)
Optical Drive: Asus - BW-16D1HT Blu-Ray/DVD/CD Writer  ($85.98 @ SuperBiiz)
Custom: Rosewill RDCR-11004 - Data Hub for 5.25" Drive Bays - Two USB 3.0  ($25.99 @ Amazon)
Total: $2717.54
Generated by PCPartPicker 2019-06-20 22:14 EDT-0400
