So i'm planning to build a new PC, it will be mostly for Racing Sims (  iracing /rfactor / Asseto Corsa ) and I just want to make sure I'm going in the right direction. Here is the setup i am going for
Ryzan 5 2600
8gb DDR4 3000MHz Vengeance LPX
gigabyte B450M
Corsair VS550 550 W
Sandisk SSD Plus 240GB
( probably GTX 1060 6GB  )
What do you guys think, will this do ? anything I should add or take away. all input is welcome and appreciated.
Thank you
https://linustechtips.com/topic/1072059-rig-for-racing-help/
20 minutes ago, oneoone said:
Thank you for the reply, sorry  I didn't put the resolution. 1080p
What is your total budget for this build?
also I advise 16GB of ram and a different power supply as that one is crappy.
Something like a corsair RMx series or be quiet 11
and why a 1060? We have Vega 56, 1660Ti, 2060 and new Navi cards being released 7/7
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1072059-rig-for-racing-help/#findComment-12639126
Hi Stormseeker,
  Thank you for the reply :)
My budget for a GPU is about £120-£150 so was going to grab one off e-bay. I will now be adding 16gb of ram over the 8 I originally wanted.
for the parts, my budget is around £300 - £350 ( not including the GPU - case  - ect )
The price of the Specs above are £301 off amazon UK.
for a while. He will be using it for mostly race sims... and knowing him a bit of fallout :)
thank you all again.
https://linustechtips.com/topic/1072059-rig-for-racing-help/#findComment-12639147
