Posted June 10, 2019 Why do I have low usage on Cpu and Gpu while I'm gaming? PC specs: CPU: Ryzen 5 2600 GPU: Nvidia GeForce RTX 2070 Motherboard: GIGABYTE B450M DS3H RAM:Dual channel G.Skill Aegis 3000Mhz 16GB 2x sticks PSU: TX CORSAIR 650W 80+ BRONZE Link to comment https://linustechtips.com/topic/1071479-low-usage/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 10, 2019 are you running the settings at all low settings? if you are not then try a different game if the same problem occurs re-install that game Link to comment https://linustechtips.com/topic/1071479-low-usage/#findComment-12633775 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 10, 2019 Why this issue popping out quite often lately? Is it because recent window or driver update? | Intel i7-3770@4.2Ghz | Asus Z77-V | Zotac 980 Ti Amp! Omega | DDR3 1800mhz 4GB x4 | 300GB Intel DC S3500 SSD | 512GB Plextor M5 Pro | 2x 1TB WD Blue HDD | | Enermax NAXN82+ 650W 80Plus Bronze | Fiio E07K | Grado SR80i | Cooler Master XB HAF EVO | Logitech G27 | Logitech G600 | CM Storm Quickfire TK | DualShock 4 | Link to comment https://linustechtips.com/topic/1071479-low-usage/#findComment-12633778 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 10, 2019 Author i tried running on low and on high fps and usage stays the same. Link to comment https://linustechtips.com/topic/1071479-low-usage/#findComment-12633780 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 10, 2019 Just now, LyndonFPSFanboy said: i tried running on low and on high fps and usage stays the same. try updating your drivers Link to comment https://linustechtips.com/topic/1071479-low-usage/#findComment-12633783 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 10, 2019 Author all of my drivers have the latest updates installed Link to comment https://linustechtips.com/topic/1071479-low-usage/#findComment-12633785 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
