I'm wondering what a good/cheapish ultra-wide of 2560x1080 or better. I don't have an exact budget but I would like cheaper if possible.
Requirements:
2560x1080
full motion stand - tilt / swivel / height adjustable
DVI or able to handle converted signal from DVI
Doesn't matter response time as will never be used for gaming it is productivity only
I am in Canada so much be available on a Canadian site. I have no brand preference either but do like the look of some of the Dell regular 16:9 professional ones.
https://linustechtips.com/topic/1071083-ultra-wide/
LG 29WK600-W
It doesn't have DVI, as to my knowledge, no decent ultrawide does. And the stand only supports tilt, however a cheap vesa mount would fix that.
https://linustechtips.com/topic/1071083-ultra-wide/#findComment-12630570
1 hour ago, Slottr said:
LG 29WK600-W
Thanks that one looks pretty much what I was hoping for, I was doubtful I could find a fully adjustable one but was worth the ask.
Is this one worth the extra $90 after shipping/taxes?
LG 34UM69G-B
https://linustechtips.com/topic/1071083-ultra-wide/#findComment-12630659
LG 34UM69G-B
Id advocate for the larger size, but the other technologies in the display like FreeSync will be useless to you
also the one I linked has HDR, which is a nice plus
https://linustechtips.com/topic/1071083-ultra-wide/#findComment-12630681
For HDR does it not require OS support? I know that I have heard a lot of issues with Ubuntu and HDR. I am using a laptop with a USB C docking station.
https://linustechtips.com/topic/1071083-ultra-wide/#findComment-12630685
Ah I see. Yeah I don’t recall any changes being made for Ubuntu’s HDR support.
Between the two though, I’d go for the larger display.
There is also this display which is another good “budget” option
https://linustechtips.com/topic/1071083-ultra-wide/#findComment-12630699
That one is a bit more than I was hoping I think I will order the one I found. Thanks for the help and comparisons
https://linustechtips.com/topic/1071083-ultra-wide/#findComment-12631551
