Hi guys what do u think of this build im doing for a friend, he play 1080p 144hz and he plays fps games and fortnite
https://uk.pcpartpicker.com/list/33rtMZ
Current PC and Peripherals
CPU: i7 6700
CPU cooler: Cryorig H7
GPU: Evga RTX 2070
Memory: 16gb Corsair RGB
HDD: 1tb WD blue
SSD: 120gb Kingston
Headphones: Hyper x Cloud
Keyboard: Logitech g810
Mouse: Logitech g502
Monitor: Aoc 60hz
Other tech I own
iPhone 8
Edifier Prisma
Amazon echo dot
Apple Airpods
Go Pro Hero 7
https://linustechtips.com/topic/1069874-build-for-a-friend/
Where have I seen this post before ... ????   Hmmm:
Any reason why you made a new thread instead of linking that in your post from yesterday?  Also from your list it looks like you didn't take much of the advice into account because your bang/buck is way off on the price of the CPU, GPU pick, case, etc.
https://linustechtips.com/topic/1069874-build-for-a-friend/#findComment-12620651
There's some stuff you can improve, but it's pretty ok.
Here's my build:
PCPartPicker Part List
CPU: AMD - Ryzen 5 1600 3.2 GHz 6-Core Processor  (£114.97 @ Laptops Direct)
Motherboard: MSI - B450 TOMAHAWK ATX AM4 Motherboard  (£89.98 @ Box Limited)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory  (£69.97 @ Laptops Direct)
Storage: Crucial - MX500 500 GB M.2-2280 Solid State Drive  (£59.99 @ Amazon UK)
Video Card: MSI - GeForce RTX 2060 6 GB VENTUS OC Video Card  (£319.97 @ Amazon UK)
Case: NZXT - H500 ATX Mid Tower Case  (£69.98 @ AWD-IT)
Power Supply: SeaSonic - FOCUS Plus Gold 550 W 80+ Gold Certified Fully Modular ATX Power Supply  (£75.46 @ Amazon UK)
Monitor: Dell - S2419HGF 24.0" 1920x1080 144 Hz Monitor  (£199.99 @ Laptops Direct)
Total: £1000.31
Generated by PCPartPicker 2019-06-04 21:17 BST+0100
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
https://linustechtips.com/topic/1069874-build-for-a-friend/#findComment-12620693
This is a better build for a gaming rig, and a little cheaper, too:
The 9400F beats the 2600X (even OCed) in most games. The Western Digital blue drive performs just as well in real world scenarios, but is cheaper. The RTX 2060 is leaps and bounds above the 1660 and it gives you access to dedicated ray tracing hardware. You COULD also go Vega 64, but no ray tracing hardware and much, much higher power consumption.
It might also be worth it to wait for Ryzen 3000 on July 7th. They might reach parity with Intel in gaming, in which case it would be the better buy.
https://linustechtips.com/topic/1069874-build-for-a-friend/#findComment-12620944
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  (£121.98 @ Aria PC) tell him to wait for zen 2 if possible.
Motherboard: Asus - PRIME X370-PRO ATX AM4 Motherboard  (£76.98 @ CCL Computers)
Storage: ADATA - XPG SX6000 Pro 512 GB M.2-2280 Solid State Drive  (£64.99 @ Box Limited)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  (£93.98 @ Amazon UK)
Video Card: Gigabyte - Radeon RX VEGA 64 8 GB Video Card  (£344.84 @ Amazon UK)
Case: Sahara - P35 ATX Mid Tower Case  (£55.47 @ Scan.co.uk)
Power Supply: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply  (£64.99 @ CCL Computers)
Monitor: ViewSonic - VX2458-mhd 23.6" 1920x1080 144 Hz Monitor  (£132.73 @ CCL Computers)
Total: £1025.93
Generated by PCPartPicker 2019-06-05 02:28 BST+0100
https://linustechtips.com/topic/1069874-build-for-a-friend/#findComment-12621229
