First of all apologies as I know this topic will already be on here but I cannot find it and it may be a good idea to get more modern information.
I am currently looking for a new monitor which will mainly be used for editing photos and some videos (no gaming at all really). I am just not sure where to look and what is good for what price. I understand I’ll be looking at a high resolution, HDR, colour accurate display, which preferably has FALD, but honestly don’t know much about monitors. My budget is around £1000 $1100 (US).
I currently have a HP Envy monitor which is okay but I’ve found the black levels are disappointing so Thank you in advance.
https://linustechtips.com/topic/1069459-monitor-help/
I don't remember now which one exactly (as i was looking for mine 2~3 months ago), but with that amount you are willing to pay you can get a very decent good monitor.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1069459-monitor-help/#findComment-12617182
Thank you for the suggestion however my budget is quite a bit higher.
https://linustechtips.com/topic/1069459-monitor-help/#findComment-12617223
