Hello, im looking to build a good gaming pc for as cheap as possible, the max i want to spend is £500 (with out the case) the best i have done so far is:
(could i make any improvements)
_______________________________________
CPU:Ryzen 5 2600
GPU: RX 570
Motherboard: gigabyte A320m-H
RAM: hyperx fury ddr4 8gb 2666hmz
Power supply: be quiet 600w
SSD: kingston a400 240GB
HDD: WD 1TB
CPU Cooler: be quite bk009
Price
CPU + GPU Bundle :£224.98
Motherboard: £39.98
RAM: £47.64
Power supply: £53.99
SSD: £27.39
HDD: £36.85
CPU Cooler: £26.99
Total: £461.31
https://linustechtips.com/topic/1066951-need-help-with-my-build/
https://pcpartpicker.com/
solution to your problems
CPU AMD 5800x_____Asus Crosshair VIII_____Asus Strix LC 360_____RAM Corsair Dominator Pro 2x8Gb 3600mhz_____ASUS RTX 3080 Strix
PSU Corsair HX1000w_____CASE Lian Li 011 Dynamic (original choice right? w/9 UNI Fans)_____Keyboard Razer BlackWidow Chroma_____Mouse Razer Deathadder Chroma_____Headphones Bose QC25_____Monitor (1) Acer Predator XB1 144hz G-Sync  (2) Benq 144hz G-Sync
Microphone Blue Yeti Black
Razer Blade 14
Also an XBOX one s.
5 minutes ago, Assuka said:
gigabyte A320m-H
Avoid A320 like the plague
6 minutes ago, Assuka said:
be quite bk009
Stick with stock cooler, it's quite good
Also, new Ryzen really soon. Wait for it, then see what your budget gets you
Primary PC:
PSU tier list
How many watts do I need?
24 minutes ago, Assuka said:
Buy a better motherboard instead of an aftermarket CPU cooler, the stock cooler will be fine.
B450 board at minimum, the arous ones being the best of the bunch for the VRM at the price point.
Try to find 3000mhz RAM
https://uk.pcpartpicker.com/product/WcjJ7P/gigabyte-b450-aorus-m-micro-atx-am4-motherboard-b450-aorus-m
Alternatively buy an R3 2200G PC with 16gbs of 3000mhz RAM and wait/save up for NAVI to throw in a GPU. Probably not worth it though.
This gives you a decent upgrade path.
PCPartPicker Part List
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  (£130.99 @ Amazon UK)
Motherboard: MSI - B450 TOMAHAWK ATX AM4 Motherboard  (£89.98 @ AWD-IT)
Memory: Corsair - Vengeance LPX 8 GB (2 x 4 GB) DDR4-3000 Memory  (£46.98 @ Aria PC)
Storage: Crucial - MX500 500 GB 2.5" Solid State Drive  (£54.78 @ Aria PC)
Video Card: MSI - Radeon RX 570 4 GB ARMOR OC Video Card  (£124.99 @ Amazon UK)
Power Supply: Corsair - CXM (2015) 450 W 80+ Bronze Certified Semi-modular ATX Power Supply  (£49.99 @ AWD-IT)
Total: £497.71
Generated by PCPartPicker 2019-05-26 02:45 BST+0100
