Have you checked for clogged filters or dirty heatsinks? The fan will be selected to adequately cool the bulb - which it is trying to do, apparently. Putting in a quieter fan will likely shorten the life of the bulb.
I would check the manual for maintenance procedures before modifying the projector.
Screwdriver specs: Long, pointy. Turns things. Some kind of metal.
Main rig:
i9-7900x | Asus X299-Prime | 4x8GB G-Skill TridentZ @3300MHz | Samsung 970 Evo 500GB | Intel 5400S 1TB | Corsair HX1200
unRAID server:
Xeon  E5-1630v4 |  Asus X99-E WS | 4x8GB G-Skill DDR4 @2400MHz | Samsung 960 EVO 250GB cache drive | 12TB spinning rust | Corsair RM750X
FreeNAS server:
AMD something-or-other | Asus prebuilt sadness | 8GB DDR3-1600 | 9TB magnetic storage | Potential fire threat
HTPC:
i7-4790 | GTX1650 | Dell Sadness | 12GB DDR3-1600 | Samsung 860 250GB | 1TB magnetic storage | James Loudspeaker SPL3 x2 | Corsair SF450
The projector is 6 years old and I've lost the manual
http://download.epson.com.sg/manuals/UsersGuide_TypeA.pdf
Main rig:
unRAID server:
FreeNAS server:
HTPC:
