My laptop is Farley old I updated it to windows ten then my cpu started playing up the cpu is a core i5 2410m. what it is doing is it cant use anymore then 34% of the cpu and the clock is only running at 0.78 Ghz, the power plan is on high performance if anyone can help me that would be awesome
https://linustechtips.com/topic/1061077-i-need-help/
You might have SpeedStep enabled.  So you say the Utilization will not go above 34 percent ?  Can you run a stability test like Aida64 which you can get for free and run a stability test to see if it will shoot to 100 percent usage and to see if your Speed goes to 2.3Ghz.  Let us know
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1061077-i-need-help/#findComment-12539991
I saw speed step on in bios so I turned it off and downloaded heavy load to test the cpu it was running at 100% in the program but when I opened task manager it was still running 34% then I ran intel processer diagnostic tool and that said it was running at 2.3 Ghz but it wasn't.
https://linustechtips.com/topic/1061077-i-need-help/#findComment-12540151
