The motherboard doesn't affect performance. you could go cheaper.
Are you planning to sli?
There's little point getting such and expensive cooler for the cpu when what you're doing is gaming.
You'd be better off with an IPS panel.
Ok ill stick with the ud3h then cause like how it looks has good reviews etc.
Not planning to sli with 780s
I would stream if i wanted to and oc to about 4.4 4.3
Benefits of IPS and recommend any good ones for under 200$ or very close to 200$?
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU: AMD FX-8350 4.0GHz 8-Core Processor ($189.99 @ Amazon)
CPU Cooler: Be Quiet SHADOW ROCK 2 87.0 CFM Rifle Bearing CPU Cooler ($49.99 @ NCIX US)
Motherboard: Asus M5A99X EVO R2.0 ATX AM3+ Motherboard ($114.97 @ OutletPC)
Memory: Kingston Black Series 8GB (2 x 4GB) DDR3-1600 Memory ($74.29 @ Amazon)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Disk ($89.99 @ Adorama)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($59.67 @ Amazon)
Video Card: EVGA GeForce GTX 780 3GB Video Card ($504.98 @ SuperBiiz)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case ($122.98 @ Newegg)
Power Supply: Corsair Professional 750W 80+ Gold Certified Semi-Modular ATX Power Supply ($89.99 @ Newegg)
Monitor: Asus VS247H-P 23.6" Monitor ($157.00 @ B&H)
Total: $1453.85
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-01-23 17:56 EST-0500)
If you want to save a few dollars
Total: $1453.85
Thanks, i havent really considered an AMD build tbh but ill look at this some more
IPS has better colors and better viewing angles. Basically, it looks much better than hte average TN panel.
Suggested edits: http://pcpartpicker.com/p/2GoOW
