i got a H-370 Prime Plus but didnt have enough money to get a supported CPU so i will try to put my i7-4790k (4.00GHz) any tips on how i can run it safely and without underclocking
(btw i dont overclock) Also what is the TDP of the H-370 Prime plus and should it be higher then the Cpu?
thanks
https://linustechtips.com/topic/1060564-i-need-help/
A 4790K won't fit into that board, the board only supports LGA 1151 V2 and the 4790K uses LGA 1150.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/1060564-i-need-help/#findComment-12535816
Return the board and go with a more affordable Ryzen CPU?
PCPartPicker Part List
Type Item Price
CPU AMD - Ryzen 5 1600 3.2 GHz 6-Core Processor $119.89 @ OutletPC
Motherboard MSI - B450M BAZOOKA V2 Micro ATX AM4 Motherboard $69.99 @ Newegg
  Prices include shipping, taxes, rebates, and discounts
  Total $189.88
  Generated by PCPartPicker 2019-05-03 12:54 EDT-0400
You're not missing much by ditching that prime board, it's not exactly feature rich.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1060564-i-need-help/#findComment-12535888
