Well safe to say I’m well and truly kicking my self right now I just bought a Arous pro Z390
mobo  and got it all in and then the pc won’t boot to bios when looking closely there’s 2 pins bent in the cpu socket and I’m guessing this is
the cause no idea  how i have done this but I’m sickened :( any idea where I go from here what are my choices buy a new Board again?
 CPU: i9 9900k @5.1ghz | GPU: Asus Strix 2080Ti OC | Cpu Cooler : Corsair H150i (360mm) | Motherboard: Gigabyte Aorus Pro Z390F  | RAM: G.Skill Trident Z RGB 32gb 3600Mhz CL16  | Boot / OS SSD : Samsung 970 Evo 500gb M.2 / Samsung 850 Evo 500Gb SSD / 1TB SEAGATE HDD Case: Corsair Obsidian 500d SE RGB | PSU: Evga SuperNova Platinum 8
https://linustechtips.com/topic/1058727-bent-cpu-socket-pins-help/
Can you post a picture of the damage?
Main PC:
CPU: AMD Ryzen 7 5700X3D | RAM:Corsair LPX 3200 mhz (32GB)
Mobo:ASUS Strix B550-F Wifi | GPU: Gigabyte 9070
Case: Sharkoon Nightshark RGB| Storage: 500 GB 970 EVO Plus 1 TB WD blue 500 GB Samsung HDD
Monitor: iiyama G-Master G2470HSU-B1 165Hz
Powersupply: Cooler Master GX III Gold 750
Main Laptop
CPU: AMD Ryzen 7 4800H | RAM: Team group 16 GB 2666 mhz
GPU: RTX 2060 (MXM swappable)
Monitor: 1080p 120Hz
Storage: 2x 1 TB Samsung 970 EVO NVMe (no raid)
Second Laptop
CPU: Intel Core I5 1235u,  RAM: Crucial 16 GB 3200 mhz
GPU: IrisXe 80 eu
Storage: 512 GB WD Digital SN530 NVMe
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
you can grab s toothpick or smth with a very small tip, try to bend the 2 pins back to place.
With a magnifying glass ?
2 minutes ago, HXRT900 said:
Put the CPU close to your Room lightbulb and line up the pins with your eye, use the tip of a small knife and slowly move the pins back into place, check all angles of the CPU.
Alright so it is possible to fix ?
