Any idea what this cable is in my pc I’m re building my pc which I have changed the mobo cpu and cooler and I’m going insane it’s my first build and I can not figure out where cables go I took pics from old board but it’s a completely different layout. Please see the cable I’m talking about and my mobo
 CPU: i9 9900k @5.1ghz | GPU: Asus Strix 2080Ti OC | Cpu Cooler : Corsair H150i (360mm) | Motherboard: Gigabyte Aorus Pro Z390F  | RAM: G.Skill Trident Z RGB 32gb 3600Mhz CL16  | Boot / OS SSD : Samsung 970 Evo 500gb M.2 / Samsung 850 Evo 500Gb SSD / 1TB SEAGATE HDD Case: Corsair Obsidian 500d SE RGB | PSU: Evga SuperNova Platinum 8
https://linustechtips.com/topic/1058249-help-with-mobo-cable/
That's a 4pin molex cable for power and is probably from your psu. It's used to power things that use a 4pin molex cable for power. It doesn't connect to your motherboard.
https://linustechtips.com/topic/1058249-help-with-mobo-cable/#findComment-12514138
Cheers for the reply super stressful for someone for the first time it’s been hard figuring stuff out
https://linustechtips.com/topic/1058249-help-with-mobo-cable/#findComment-12514141
image.png.2d704677b59a58f5ad2bafeee71afb82.pngFrom the looks of it you're just about set up, you can likely ignore that molex connector unless you spot something it goes into, otherwise your motherboard isn't gonna need it.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1058249-help-with-mobo-cable/#findComment-12514147
Haha yeah just spent another hour finding some screws 6 hours to change mobo cpu and cooler safe to say I’m not quitting my day job to build Pc”s ??
https://linustechtips.com/topic/1058249-help-with-mobo-cable/#findComment-12514176
Do you have any idea where these go?
https://linustechtips.com/topic/1058249-help-with-mobo-cable/#findComment-12514211
Both the motherboard and the cables themselves should have labels, pwr, res, led, etc.
LEDs have + and - terminals, buttons don't, so you can't plug buttons in backwards.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1058249-help-with-mobo-cable/#findComment-12514216
Download the motherboard manual, it shows exactly where they go.  Or look on the motherboard itself, the pins are marked and the words are on the motherboard itself.
The other side of those connectors on your finger has the letters identifying what they are.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1058249-help-with-mobo-cable/#findComment-12514217
Yeah they do nearly there just stuck installing  the h150i pro saying I need to plug it into a sata power plug
https://linustechtips.com/topic/1058249-help-with-mobo-cable/#findComment-12514325
Are you objecting to reading manuals for a moral or religious reason?
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1058249-help-with-mobo-cable/#findComment-12514339
I am reading the manual but I just  don’t see a sata port on my mother board clearly I’m blind ?
https://linustechtips.com/topic/1058249-help-with-mobo-cable/#findComment-12514342
https://linustechtips.com/topic/1058249-help-with-mobo-cable/#findComment-12514343
You said SATA power plug, look on the PSU and it's cables... :)
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1058249-help-with-mobo-cable/#findComment-12514354
So look for this on my psu?
https://linustechtips.com/topic/1058249-help-with-mobo-cable/#findComment-12514369
Yeah, it's the same plug that goes into Hard Drives and SSDs, etc.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1058249-help-with-mobo-cable/#findComment-12514384
