Hi guys,
I was thinking about removing stock cooler from my Zotac GTX 1080ti mini and using dual tower cpu heatsink on my GPU. I wanted to know can I cover the remaining part of the GPU with thermal pads and put heatsink on parts like vram and few other IC. Would that create any problems of over heating or thermal throttle. I have attached image for the parts that I want to cover with thermal pad. The CPU heatsink fits perfectly on the GPU. I am going to use this small heatsink for vram. The reason to cover most of the parts is to avoid heatsink to touch other parts and avoid short circuit.Screenshot_20190408-112746__01__01.jpg.666f1337e60d97b7b5ede8bcdaae98f2.jpgScreenshot_20190408-112746__01.jpg.75fca701c26ffecbb00aa09442a69528.jpgIMG-20190422-WA0004.jpg.44dd9ec873792924956c188a30621f93.jpgIMG-20190422-WA0003.jpg.042bcd2b6d9af642c76bb0bacb8a4b75.jpgae_1555600922190.thumb.jpg.249a3d391511dd3f8e3408d4d4c421db.jpg
Screenshot_20190408-082137__01.jpg.0223e87ab641a2cd53a1c6ffc6f47582.jpgThanks in advance.
https://linustechtips.com/topic/1058047-gpu-cooling-with-cpu-dual-tower/
Those extra heatsinks, should not have thermal pads underneath them. They are supposed to be applied with some sort of thermal adhesive, and NOT thermal pads. I'd say, you're just insulating the parts that are covered, they way you've done it. You also are going to have little airflow over the surface mounted components, because you're using a tower cooler and not a downdraft cooler.
Not strictly helpful, but it also looks totally terrible!
The vram Temp are not going down
