I have a GTX 1080 and I I'm using 4 of it's video outputs, which seems to be the maximum that most graphics cards support. I'm using the HDMI for my vive, and the 3 displayports for my 3 monitors.
I'd like to duplicate the feed of my center monitor and send it to a capture card over HDMI. I can't seem to find a displayport splitter that doesn't act like 2 separate displays instead of just mirroring the input (and I can only use 4 display outs) and I'm also worried about that introducing a little lag or not being able to support 144hz to my monitor.
If I was to buy a low-end GPU like a GT 1030 or a GTX 750, could I pop that in and use it to mirror my center screen in Windows display settings and not cause much of a hit to my performance?
https://linustechtips.com/topic/1057843-second-small-gpu-for-more-monitors/
Technically you should, albeit not with fullscreen applications (iirc).
If you have an iGPU you could try using that?
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
CPU is a 9600K. Yeah I thought about using the iGPU but I know that results with that can be a little hit-and-miss sometimes and I'm not sure what kind of hit my CPU would take for that, I do love my multitasking and it's already hard enough to even watch a video when Hammer is compiling a CS map and pegging my CPU, so I was hoping a dedicated card might help with that a little.
I'm open to whatever suggestions. Thanks for any help
