Hello!
I can't decide if whether which one I should get:
https://www.thermaltake.com/chassis/mini_case_/core/c_00002373/core_v1/design.htm
https://www.thermaltake.com/products-model.aspx?id=c_00002727
I want the F1 Supressor one but I am worried about the airflow. Core V1 has a front mesh panel that I think would help with the airflow; F1 Supressor has a almost covered front yet the same 200mm fan.
Would it make a great deal of difference and which one should be taken if you consider the specs below;
MSI B450I gaming plus
Ryzen5 2700
be quiet! pure rock slim
16GB corsair lpx 2400
GTX 1070 EVGA FTW
Corsair TX750M
Thanks in advance :)
Edited by dnakruf
added cpu cooler
https://linustechtips.com/topic/1057390-mini-itx-case-choice/
This is just my guess, so take my comment with a grain of salt:
The Core V1 may have a lot of holes on the front panel, but it's not mesh. In fact, I think that it might be a similar case to the Q500L, which has a lot of holes - but combined they only cover 20% of the total surface area of the front panel.
With that said, I think there may be almost no difference between the two cases you presented. So, I'm inclined to tell you that you may very well purchase the F1 Suppressor.
Then again, it's just my personal opinion. Good luck!
RGB & Fan control ULTIMATE GUIDE !
https://linustechtips.com/topic/1057390-mini-itx-case-choice/#findComment-12506087
Thank you very much! :)
https://linustechtips.com/topic/1057390-mini-itx-case-choice/#findComment-12506091
