Need another option for cpu
Solved by Shimejii,
1 minute ago, Galion said:I was more worried on stability and end user link security, as I need to be able to program a site lock. Encryption to run 24/7, and a security software I'm not used to that's supposed to be connected to the principal's home system
The Inner Cyber Security inside me twitched when you mentioned a software connected to a home computer from the principal, usually a person thats fairly Awful with computers and causes more intrusions then most people know.
All of that should be fine, None of that sounds like it would be an issue.
