hii guys i have old pc
i7 2600
msi b75m-p45
8gb ram
rm1000x
and 7970
p.s. the gpu work with other pc
when i try this gpu with this mobo seems like not recognize
i can only use integrated gpu
the gpu fan spin but no output signal
Fast boot disaled
pcie 3gen enabled
PLS HELP ME
https://linustechtips.com/topic/1053510-pcie-problem-or-what/
If you get integrated graphics signal, does the GPU show up in device manager when you boot via integrated graphics and the graphics card plugged in?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1053510-pcie-problem-or-what/#findComment-12470573
2 minutes ago, wlaro said:
no
ther is only " intel integrated gpu"
Have you tested another GPU with this suspect motherboard?
Primary PC:
PSU tier list
https://linustechtips.com/topic/1053510-pcie-problem-or-what/#findComment-12470583
1 minute ago, wlaro said:
yes it works
what does it say in BIOS? I believe a graphics device should show up there.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1053510-pcie-problem-or-what/#findComment-12470596
with msi b75m p45  doens't show anything in the bios
with a newer pc bios show radeon 7970
might be worth a BIOS update for that MSI board then
Primary PC:
PSU tier list
https://linustechtips.com/topic/1053510-pcie-problem-or-what/#findComment-12470614
