LTT Hoodie
Go to solution Solved by Guest,
It's not in their store, so it's either a test run or some old merch (from their previous store).
If it's a test run then it might appear in the store sometime in the future.
Dang, I like their designs but I'm a guy who wears hoodies 24/7. Thank you anyway, at least I have closure.
https://linustechtips.com/topic/1052745-ltt-hoodie/#findComment-12463846
