Located in the US with a budget of 1,000$. Would like to stay right around that budget. Would be using for 144hz 1080p gaming on competitive games like csgo and also 1080p casual gaming that doesn't need to be a steady 144. Currently thinking of a 2600x paired with a 2060 for that range but that's subject to change.
https://linustechtips.com/topic/1052518-first-build-help/
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  ($164.89 @ OutletPC)
Motherboard: ASRock - B450M PRO4 Micro ATX AM4 Motherboard  ($76.31 @ Amazon)
Memory: G.Skill - Aegis 16 GB (2 x 8 GB) DDR4-3000 Memory  ($77.99 @ Newegg)
Storage: HP - EX900 250 GB M.2-2280 Solid State Drive  ($39.99 @ Newegg)
Storage: Seagate - Barracuda 1 TB 3.5" 7200RPM Internal Hard Drive  ($38.69 @ Amazon)
Video Card: Asus - GeForce RTX 2070 8 GB DUAL OC Video Card  ($469.99 @ Newegg)
Case: Thermaltake - Versa H18 Tempered Glass MicroATX Mini Tower Case  ($39.99 @ Newegg)
Power Supply: Corsair - CX (2017) 550 W 80+ Bronze Certified ATX Power Supply  ($38.96 @ Newegg)
Total: $946.81
Generated by PCPartPicker 2019-04-07 12:27 EDT-0400
https://linustechtips.com/topic/1052518-first-build-help/#findComment-12461243
