Bitspower is coming out with a white POM D5 top. A white top upgrade kit will most likely follow  :)
The color looks kinda cheap and plasticy imo, but it might look breathtaking in real life.
I might pick this up when i get around to upgrading my black/white system with a watercooling loop this year  :wub:
Features:
1. Design For Universal D5/MCP655 MOD KIT.
2. G1/4" Out-Let x2 ; 1/4" In-Let x3.
3. Best CNC Machined Surface.
4. RoHS Compliant.
Dimensions: 62x62x43 MM
Material : POM/Delrin/Acetal.
Color: White.
Included :
1. D5/MCP655 MOD TOP “S” X 1PCS.
2. M4*6 MM Screw X 4PCS.
3. G1/4" Matt Black Low-Profile Stop Fitting X 3PCS.
Source
https://linustechtips.com/topic/105158-bitspower-white-d5-mod-top/
Looks cool. Hope to see that build of your in the build log!
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
My brain regarding this matter is like your avatar, doesnt believe it
photo-18538.gif?_r=1387639016
Listen if you care.
One thing for sure: it looks like if it was 3D Printed...
It does look kinda cheap.. I'm still going to go with a black one for my build.. Which you can't get in the UK... ffs.
I too prefer the look of the classic Bitspower black, but i want to see TTL's review of this before i buy either :)
