Wireless Mouse Stuttering! :(
Go to solution Solved by Turtle Rig,
11 hours ago, Turtle Rig said:
Hey all, so I have had this problem with my mouse in signature.  I have the latest Logitech drivers just FYI.  When moving the mouse around its not smooth and sometimes jerks and stutters.  As soon as I connect the cable the problem is gone.  I have tried the wireless adapter on usb 2.0 hub, and usb 2.0 on motherboard and usb 3.0 on motherboard.  I move the mouse and it doesn't move or lags.  What can I do about this ?  This problem doesn't exist with my old mans same mouse and cousins same mouse.  I basically need to connect the cable or else it will freeze and stutter and jerk.  What can I do about this ?  Thanks in advance for your help!!! :(
I plugged another hub on top of the hub I already have connected to motherboard and the stuttering is gone.  Mouse moves smooth and doesn't get stuck.  Thanks all!!! giddy!
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1050416-wireless-mouse-stuttering/
