Im trying to make a mini itx build with a budget of 500-550 USD, i made this but does anyone have any suggestions or any comments on how i can improve it or add and make it better without adding too much cost? i made it keeping in mind the price of a windows key. Thank you.  https://pcpartpicker.com/list/dcgBV6
https://linustechtips.com/topic/1048565-mini-itx-build/
Small modifications, you definitely need some dual channel and no doubt an SSD, plus you don't have to pay for windows, you can use it for free.
Edited by fasauceome
better list
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1048565-mini-itx-build/#findComment-12428871
https://pcpartpicker.com/list/GzMCYT
CPU: AMD - Ryzen 3 2200G 3.5 GHz Quad-Core Processor  ($93.99 @ SuperBiiz)
CPU Cooler: Noctua - NH-L9a-AM4 33.84 CFM CPU Cooler  ($39.90 @ Amazon)
Motherboard: ASRock - B450 GAMING-ITX/AC Mini ITX AM4 Motherboard  ($104.99 @ Newegg Business)
Memory: G.Skill - Ripjaws V Series 8 GB (2 x 4 GB) DDR4-3200 Memory  ($63.99 @ Newegg)
Storage: Intel - 660p Series 512 GB M.2-2280 Solid State Drive  ($69.89 @ OutletPC)
Case: Inwin - BQ656T.AD150TB3 Mini ITX Tower Case  ($68.93 @ Amazon)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($99.39 @ OutletPC)
Total: $541.08
The APU is not great for a future GPU upgrade, as the integrated graphics will go to waste and the CPU side is not that strong.
So why not go for the sexy real small form factor here?
https://linustechtips.com/topic/1048565-mini-itx-build/#findComment-12429223
Memory: G.Skill - Aegis 8 GB (1 x 8 GB) DDR4-3000 Memory  ($43.98 @ Newegg)
Storage: MyDigitalSSD - BP5e Slim 7 240 GB 2.5" Solid State Drive  ($39.99 @ Amazon)
Storage: Seagate - Barracuda 1 TB 3.5" 7200RPM Internal Hard Drive  ($39.99 @ Amazon)
Video Card: ASRock - Radeon RX 570 4 GB Phantom Gaming D Video Card  ($129.99 @ Newegg)
Case: Silverstone - Sugo SG13B Mini ITX Tower Case  ($50.50 @ B&H)
Power Supply: SeaSonic - FOCUS Gold 450 W 80+ Gold Certified Semi-Modular ATX Power Supply  ($39.99 @ Newegg)
Total: $543.42
Generated by PCPartPicker 2019-03-26 23:42 EDT-0400
https://linustechtips.com/topic/1048565-mini-itx-build/#findComment-12429319
52 minutes ago, mach said:
You should avoid using single channel memory on ryzen platform especially for APU.
Also, whats the point of using APU with a dedicated gpu?
the 2200G is only $10 more than the 1200, the iGPU helps if he needs to diagnose problems with his rig. having a single stick makes it easier for him to upgrade to 16gb in the future.
https://linustechtips.com/topic/1048565-mini-itx-build/#findComment-12429555
https://www.gamersnexus.net/hwreviews/3261-r3-2200g-r5-2400g-review-gaming-benchmarks-vs-gt-1030
Take a look at how single channel memory would impact the performance on an APU
If I'm gonna get a dedicated gpu I'll choose r3 1300x instead.
https://linustechtips.com/topic/1048565-mini-itx-build/#findComment-12429719
Except i placed an rx 570 in the build, i'm not telling him to use the iGPU for games.
https://linustechtips.com/topic/1048565-mini-itx-build/#findComment-12429918
