Need help picking a switch
Go to solution Solved by toasty6776,
I don't know that specific model but generally speaking, TP-Link makes quite good networking equipment so you should be alright there.
Hello all,
I've never owned a switch before just mostly wireless routers.
I'm looking for a 8+ port switch that's user friendly but at the same time I can learn from it.
I'm kind of a ASUS fan boy since most of my routers have been that brand.
Any suggestions would be great.
My budget is 200 or less, maybe 250 if it's the perfect fit.
https://linustechtips.com/topic/1048561-need-help-picking-a-switch/
Do you actually need the management features of a higher end switch? Because if you literally just want to connect a bunch of devices to each other, you should be fine with a $30 unmanaged switch.
WHIPLASH
CPU: Intel Core i7 6700k @4.7GHz
RAM: Corsair Vengeance RGB DDR4 2x8GB @3000MHz
MOBO: Asus ROG Maximus VIII Ranger
GPU: EVGA GTX 1080 FTW2
PSU: EVGA Supernova 650GS
CASE: Fractal Design Define S
I mean I wouldn't mind some advanced features, but plug and play sounds nice.
Advanced features would include VLANs (more of an enterprise feature) and link bonding but most people don't really need those features for personal use. You do also get the ability to monitor the traffic that comes through the switch (that is quite interesting, I admit) but I don't think it's worth paying literally triple or even more for the switch.
WHIPLASH
TP-Link 16 Port Switch Gigabit | Ethernet Network Switch | Shielded Ports | Fanless | Desktop | Sturdy Metal | Traffic Optimization | Unmanaged (TL-SG116) https://www.amazon.com/dp/B07GR9S6FN/ref=cm_sw_r_cp_apa_i_4bRMCb710VCPA
This kind of sounds right up my ally.
WHIPLASH
Thanks for all your help Toasty!
You are quite welcome!
WHIPLASH
