The only led in this build is it's front panel and it being a rgb you can choose whatever color you like.
Silverstone RVZ03 (black)
Ryzen R5 2600 + wraith stealth
Shadow Rock LP - 130tdp (Optional)
Msi B450i gaming plus ac motherboard (black/red)
Crucial Ballistix Elite 3200mhz cl15 16gb (black)
Zotac RTX 2080 Twin fan 8gb non-oc edition (black)
Adata XPG SX8200 Pro nvme 512gb boot drive/drivers
Samsung 860 Evo/Qvo 1tb 2.5 inch ssd mass storage
Corsair SF600 SFX 600w 80+ platinum full modular
*the shadow rock was meant in case the user would like to overclock.
*whichever ssd you choose for mass storage is optional I'm using both as I have dual storages.
*this build was designed to be quiet both visually and in operational.
*the zotac's card is the cheapest all black 2080 card.
Best Value Build List
Budget 1080p System (RGB) https://pcpartpicker.com/list/7v2Lmq - (this build comes with two free games with the RX 570)
https://linustechtips.com/topic/1048292-nightvision-itx-build/
