Hello.
Long story short:
Is it worth buying a Non-reference PCB for watercooling?
My guess would be that a reference PCB would be just fine, since the problem with most reference cards are temps. However, non-reference cards have more power delivery, different VRM etc...
(If there are no substantial differences between them, I'll be glad to save some money by buying a reference PCB)
If you can find a block within a decent price range for non-ref. PCB then go for it. It can only be better than reference with power delivery and such.
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
You have a much bigger choice of waterblocks with a reference PCB.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
Depends which card you are going for. If you are getting a reference car you have a lot choice. If you get something like a DUCII or Lightning you will have to get a EK block.
Quote me to get a reply!
no it's all in the silicon lottery. My friend bought a GTX 780 Lightning and it overclocks 20Mhz... :D
Yeah, im aware of the "lottery"... But keep in mind that (most) Non-ref cards already come OC'd.
My guess is that both, ref and non-ref, will have the same price range, waterblock wise...
Yeah, not only that, but I save money with a ref card...
R9 290
(EK was already on my mind  :ph34r: )
Look on EK's website to find blocks.
I believe that you didn't get the point of my topic  :lol:  Maybe I wasn't clear enough...
Well, Im trying to understand if a Non-Reference PCB still has benefits over a reference card while watercooled.
I've heard that the low overclocks on the 290 is due to the poor power delivery on the reference model.
Main Rig
Phone
Well that is some usefull info... I hope its just coincidence (regarding the so called silicon lottery).
Linus on the other hand had a 290 which OC'd like a beast (Linus's vid about the reference 290)
