like this?
I think you can do it with a RGB light, it can also be turned off so it'd work
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
https://linustechtips.com/topic/1046880-need-smart-home-help/#findComment-12414758
6 minutes ago, aezakmi said:
like this?
No i mean for example lets say im going to bed i can say alexa turn off the lights and when i wake up i can go alexa turn on the lights
https://linustechtips.com/topic/1046880-need-smart-home-help/#findComment-12414776
You need a supported "smart" switch for every light you want to control like that.
https://www.amazon.com/Gosund-Control-required-installation-listed/dp/B07DQDNBZ2/ref=sr_1_3
sudo chmod -R 000 /*
https://linustechtips.com/topic/1046880-need-smart-home-help/#findComment-12414799
Just pickup any Alexa compatible wifi smart plug or switch or Zwave hub and plug or switch then set it up according to the manufacturer instructions. If you require a wall switch to be wired in, you may have to hire an electrician to wire it in for you.
Typically it is as easy as adding a skill to your echo or granting permission to your Amazon account to be able to control your device with your echo.
There's no place like ~
Problems and solutions:
FreeNAS
Dell Server 11th gen
ESXI
https://linustechtips.com/topic/1046880-need-smart-home-help/#findComment-12414805
