Hey. I need to be able to download a .zip file using Java. However, the file is always 1KB even though the original file is 28MB. I've tried many different methods that I found online but they all return the same result. I don't know what's happening.
The methods I've tried:
Buffered Streams:
try (BufferedInputStream in = new BufferedInputStream(url.openStream());
			FileOutputStream fileOutputStream = new FileOutputStream(codeName + ".zip")) {
			byte dataBuffer[] = new byte[1024];
			int bytesRead;
			while ((bytesRead = in.read(dataBuffer, 0, 1024)) != -1) {
				fileOutputStream.write(dataBuffer, 0, bytesRead);
		} catch (IOException e) {
			e.printStackTrace();
Java NIO:
try {
			ReadableByteChannel readChannel = Channels.newChannel(url.openStream());
			FileOutputStream fileOS = new FileOutputStream(codeName + ".zip");
			FileChannel writeChannel = fileOS.getChannel();
			writeChannel.transferFrom(readChannel, 0, Long.MAX_VALUE);
			fileOS.close();
			readChannel.close();
And finally this one I don't know what it is:
try {
			InputStream in = url.openStream();
			Files.copy(in, Paths.get(codeName + ".zip"), StandardCopyOption.REPLACE_EXISTING);
All of these return the same results, a 1KB zip that cannot be opened. The original file IS a 28MB zip file and I've verified the download works correctly by downloading it myself normally.
CPU: Intel Core i7 8700
GPU: Gigabyte GeForce GTX 1070
MOBO: ASUS Z370-F STRIX
RAM: 16GB Corsair Vengeance DDR4 2133MHz
https://linustechtips.com/topic/1046842-help-with-downloading-files-in-java/
Hi,
Try a different source url and destination filename.
Likely you are looking in the wrong place for either.
So, try a different file, and afterwards if the 1kb persists, check if the 1kb is equal in content as a manual download or not.
Look at the bytes downloaded, likely its html describing a 404, 401 or 500 error describing a issues likely caused by malformed url (did you properly double escape / for example in constant urk strings?)h
Hope this helps
try {
Oops forgote to quote in above post for notification :)
I fixed it, I needed to use HTTPS instead of HTTP
